Boat House
1436 jon questions about motors...O/B and transom troller
<blockquote data-quote="kstrayhorn" data-source="post: 412133" data-attributes="member: 15815"><p>Remember that doing that is going to give you propulsion from the corner of the boat and might make it difficult to maneuver where/how you want to. Previous owner of mine had two plates welded at 90° mounted to the bow for a clamp-on. I'd think that would be your best option, but if you're against that, maybe some kind of swivel bracket? I'm imagining 2 plates with a pin in the middle of one and a sleeve on the other. That should allow you raise the mounting point as well as swivel the trolling motor out of the way when it's up to use the outboard</p></blockquote><p></p>
[QUOTE="kstrayhorn, post: 412133, member: 15815"] Remember that doing that is going to give you propulsion from the corner of the boat and might make it difficult to maneuver where/how you want to. Previous owner of mine had two plates welded at 90° mounted to the bow for a clamp-on. I'd think that would be your best option, but if you're against that, maybe some kind of swivel bracket? I'm imagining 2 plates with a pin in the middle of one and a sleeve on the other. That should allow you raise the mounting point as well as swivel the trolling motor out of the way when it's up to use the outboard [/QUOTE]
Boat House
