Motors
16 HP engine not starting
<blockquote data-quote="screwballl" data-source="post: 183532" data-attributes="member: 4837"><p>I tore it apart after work today. There are 2 butterfly valves and the inside one closest to the block was sticking closed. After I hosed it all down with carb cleaner it freed itself up. Also hosed off the end of the spark plug with carb cleaner then dried it off. </p><p></p><p>Started first try! Thanks for the help all, I was hoping it wasn't something more involved and it wasn't.</p></blockquote><p></p>
[QUOTE="screwballl, post: 183532, member: 4837"] I tore it apart after work today. There are 2 butterfly valves and the inside one closest to the block was sticking closed. After I hosed it all down with carb cleaner it freed itself up. Also hosed off the end of the spark plug with carb cleaner then dried it off. Started first try! Thanks for the help all, I was hoping it wasn't something more involved and it wasn't. [/QUOTE]
Motors
