Boat House
1958 richline ...help please
<blockquote data-quote="dually66" data-source="post: 226142" data-attributes="member: 7007"><p>The splashwell and surroundings are rivited on. I just had an aluminum welder out here to look at it. He felt that after removing the exterior wood, I should have a 1/4" sheet of aluminum put on the rear of boat to my specs because I need to raise the transom up anyway. The transom wood is solid but weak in comparison to the weight of the motor. I was thinking that after i installed the outer skin with new height, I would glass 2 sheets of 3/4" oak hardwood ply, (after i water seal it)...then brace it in place on inside of transom interior. Any thoughts?...or am i on right track?</p></blockquote><p></p>
[QUOTE="dually66, post: 226142, member: 7007"] The splashwell and surroundings are rivited on. I just had an aluminum welder out here to look at it. He felt that after removing the exterior wood, I should have a 1/4" sheet of aluminum put on the rear of boat to my specs because I need to raise the transom up anyway. The transom wood is solid but weak in comparison to the weight of the motor. I was thinking that after i installed the outer skin with new height, I would glass 2 sheets of 3/4" oak hardwood ply, (after i water seal it)...then brace it in place on inside of transom interior. Any thoughts?...or am i on right track? [/QUOTE]
Boat House
