Motors
1967 Evinrude 18hp Fastwin low speed sputtering and missing
<blockquote data-quote="flyingvranch" data-source="post: 354309" data-attributes="member: 13744"><p>A quick update. I found out that it was mostly too lean on the idle speed needle. I turned it out 1 1/2 turns and got it fine tuned and it runs nearly perfect now. I do think the crank seals are leaking as it dribbles a little oil mixture from under the flywheel. It only misses very seldom now and is running very nicely and good enough for me. Thanks for all of the great help and replies!</p></blockquote><p></p>
[QUOTE="flyingvranch, post: 354309, member: 13744"] A quick update. I found out that it was mostly too lean on the idle speed needle. I turned it out 1 1/2 turns and got it fine tuned and it runs nearly perfect now. I do think the crank seals are leaking as it dribbles a little oil mixture from under the flywheel. It only misses very seldom now and is running very nicely and good enough for me. Thanks for all of the great help and replies! [/QUOTE]
Motors
