Motors
1969 35ho johnson prop issue-
<blockquote data-quote="luigirox" data-source="post: 440164" data-attributes="member: 22390"><p>Thanks guys I sent the new prop and original to the prop shop. I think the are going to look at the hubs.</p><p></p><p>I think the hub was not drilled out correctly on the prop only because it seemed to get stuck in the same spot if I tried to put it on backwards. I mean same spot on the prop. So 3/4 the way on normal 1/4 backwards.</p><p></p><p>We will see.</p></blockquote><p></p>
[QUOTE="luigirox, post: 440164, member: 22390"] Thanks guys I sent the new prop and original to the prop shop. I think the are going to look at the hubs. I think the hub was not drilled out correctly on the prop only because it seemed to get stuck in the same spot if I tried to put it on backwards. I mean same spot on the prop. So 3/4 the way on normal 1/4 backwards. We will see. [/QUOTE]
Motors
