Motors
1969 Evinrude 9.5 hp. Model#9922S
<blockquote data-quote="ultra353" data-source="post: 171969" data-attributes="member: 2751"><p>Your serial # of 9922 indicates it is a 1969 and it originally being a short shaft model-"22" whereas 9923 would indicate a long shaft. If your going to convert it back to the short your gonna need the short driveshaft, water tube and shift rod which can be usually be located on ebay. Also on your lower unit it looks like you have already used a self etching primer for the aluminum. For the paint i would just use an acrylic lacquer paint, it should easily withstand the heat as they painted the whole motor with same paint.</p></blockquote><p></p>
[QUOTE="ultra353, post: 171969, member: 2751"] Your serial # of 9922 indicates it is a 1969 and it originally being a short shaft model-"22" whereas 9923 would indicate a long shaft. If your going to convert it back to the short your gonna need the short driveshaft, water tube and shift rod which can be usually be located on ebay. Also on your lower unit it looks like you have already used a self etching primer for the aluminum. For the paint i would just use an acrylic lacquer paint, it should easily withstand the heat as they painted the whole motor with same paint. [/QUOTE]
Motors
