Motors
1969 Mercury 7.5 HP repairs
<blockquote data-quote="JMichael" data-source="post: 276800" data-attributes="member: 7544"><p>I had a 66 model 3.9 merc that had the same 2 issues. I replaced the impeller and rebuilt the fuel pump. The water flowed slightly better but still not quite what I thought it should be. It continued to die unless I kept the bulb pumped. After quite a bit of testing, I discovered the O-ring inside the female connecter (that attaches the line to the engine) had a small nick in it, allowing it to suck just enough air to prevent the pump from being able to do it's job. I replaced the O-ring and never had another fuel problem. I continued to run the motor with what I considered weak water flow up until I sold the motor this spring.</p></blockquote><p></p>
[QUOTE="JMichael, post: 276800, member: 7544"] I had a 66 model 3.9 merc that had the same 2 issues. I replaced the impeller and rebuilt the fuel pump. The water flowed slightly better but still not quite what I thought it should be. It continued to die unless I kept the bulb pumped. After quite a bit of testing, I discovered the O-ring inside the female connecter (that attaches the line to the engine) had a small nick in it, allowing it to suck just enough air to prevent the pump from being able to do it's job. I replaced the O-ring and never had another fuel problem. I continued to run the motor with what I considered weak water flow up until I sold the motor this spring. [/QUOTE]
Motors
