Motors
1975 Johnson 25 hp carb help
<blockquote data-quote="jonmac3569" data-source="post: 219655" data-attributes="member: 6462"><p>Ok, I will have to check that out. I turned it clockwise if you were looking down from the flywheel. I just held the lower unit with the crankshaft pointing toward the ceiling, and turned it clockwise.</p><p></p><p>I think I will take it back apart and just make sure the impellers are exactly the same. I compared them before I changed it out but I didnt check the exact thickness.</p></blockquote><p></p>
[QUOTE="jonmac3569, post: 219655, member: 6462"] Ok, I will have to check that out. I turned it clockwise if you were looking down from the flywheel. I just held the lower unit with the crankshaft pointing toward the ceiling, and turned it clockwise. I think I will take it back apart and just make sure the impellers are exactly the same. I compared them before I changed it out but I didnt check the exact thickness. [/QUOTE]
Motors
