Motors
1985 Johnson 30hp
<blockquote data-quote="Mattbowen61990" data-source="post: 343582" data-attributes="member: 13610"><p>Thanks, yes it runs, it has fine the past few days. I am unsure of what the "starting position is on the motor tiller, it has two positions, one has a black dot with two columns going from each end, and a position that has a arrow in a circular path. Thanks for posting that info, I looked under the hood, and saw that the slow idle adj. screw was backed way out, so I screwed it in and backed it out about a turn and a half. Planning on testing it tomorrow to see if that was the problem.</p></blockquote><p></p>
[QUOTE="Mattbowen61990, post: 343582, member: 13610"] Thanks, yes it runs, it has fine the past few days. I am unsure of what the "starting position is on the motor tiller, it has two positions, one has a black dot with two columns going from each end, and a position that has a arrow in a circular path. Thanks for posting that info, I looked under the hood, and saw that the slow idle adj. screw was backed way out, so I screwed it in and backed it out about a turn and a half. Planning on testing it tomorrow to see if that was the problem. [/QUOTE]
Motors
1985 Johnson 30hp
