Motors
1986 Johnson 15 hp HELP
<blockquote data-quote="jellio5" data-source="post: 205111" data-attributes="member: 5172"><p>I think we need some more info.....when you say converting it what do you mean...there isn't much you can do on a 15HP. Did you check for spark? That would be my first thought. Take some of your premix gas and put it in a squirt bottle and give it a couple shots in the hole in the air box and see if it will fire that would be the first step. Is your fuel tank and line functioning correctly that is another thing you need to check first. Also check your tiller handle and make sure it's functioning correctly......basically eliminate all the outside stuff first before diving into the motor itself...once you've done that check for spark if you have spark then it's either air or fuel.</p></blockquote><p></p>
[QUOTE="jellio5, post: 205111, member: 5172"] I think we need some more info.....when you say converting it what do you mean...there isn't much you can do on a 15HP. Did you check for spark? That would be my first thought. Take some of your premix gas and put it in a squirt bottle and give it a couple shots in the hole in the air box and see if it will fire that would be the first step. Is your fuel tank and line functioning correctly that is another thing you need to check first. Also check your tiller handle and make sure it's functioning correctly......basically eliminate all the outside stuff first before diving into the motor itself...once you've done that check for spark if you have spark then it's either air or fuel. [/QUOTE]
Motors
