Motors
1989 Mariner 5M
<blockquote data-quote="SF Flats Fisher" data-source="post: 339454" data-attributes="member: 13320"><p>I haven't looked into that, that's a good idea though. I assume it'll be a little pricey, but probably stronger than anything I could buy. The one that is on the motor now broke off inside the casing pretty much, I was lucky enough to be able to stick a flathead in there and turn it into neutral so I could test run it. I'll have to call around.</p></blockquote><p></p>
[QUOTE="SF Flats Fisher, post: 339454, member: 13320"] I haven't looked into that, that's a good idea though. I assume it'll be a little pricey, but probably stronger than anything I could buy. The one that is on the motor now broke off inside the casing pretty much, I was lucky enough to be able to stick a flathead in there and turn it into neutral so I could test run it. I'll have to call around. [/QUOTE]
Motors
1989 Mariner 5M
