Motors
1992 25HP Evinrude Primer???
<blockquote data-quote="Whoopbass" data-source="post: 219103" data-attributes="member: 2243"><p>I run the same motor and have pretty much the same issues. It idles like crap even though i've adjusted the mixture knob every which way. I've never had an idle problem with a regular pull choke outboard so it must have something to do with the primer system. Sometimes when i'm idling and its running like crap I can get it to idle better by pulling out the primer knob a 1/4"-1/2" but that only seems to work sporadically and only for a short time. Runs fine after 1500 rpm or so.</p><p>My riding lawn mower was idling like crap so I pulled the carb off and dismantled it then soaked it in pine-sol overnight and that fixed the problem so i'm going to try that with my outboard when I get a chance. Pine-Sol seems to clean better then any carb cleaner on the market.</p></blockquote><p></p>
[QUOTE="Whoopbass, post: 219103, member: 2243"] I run the same motor and have pretty much the same issues. It idles like crap even though i've adjusted the mixture knob every which way. I've never had an idle problem with a regular pull choke outboard so it must have something to do with the primer system. Sometimes when i'm idling and its running like crap I can get it to idle better by pulling out the primer knob a 1/4"-1/2" but that only seems to work sporadically and only for a short time. Runs fine after 1500 rpm or so. My riding lawn mower was idling like crap so I pulled the carb off and dismantled it then soaked it in pine-sol overnight and that fixed the problem so i'm going to try that with my outboard when I get a chance. Pine-Sol seems to clean better then any carb cleaner on the market. [/QUOTE]
Motors
