Motors
1993 Evinrude 4HP
<blockquote data-quote="aviator950" data-source="post: 231665" data-attributes="member: 7239"><p>1993 Evinrude 4HP</p><p></p><p>Does anyone have the above engine? I need some help. I need the measurement in inches (measured from the base at the engine block to the tip) of the the stud that comes off the block that the starter coil plate is attached to.</p><p></p><p> A mechanic broke the stud when replacing the pull cord and and welded the stud but I think the length that he built it up to is not correct.</p><p></p><p>Thanks</p></blockquote><p></p>
[QUOTE="aviator950, post: 231665, member: 7239"] 1993 Evinrude 4HP Does anyone have the above engine? I need some help. I need the measurement in inches (measured from the base at the engine block to the tip) of the the stud that comes off the block that the starter coil plate is attached to. A mechanic broke the stud when replacing the pull cord and and welded the stud but I think the length that he built it up to is not correct. Thanks [/QUOTE]
Motors
1993 Evinrude 4HP
