1994 Sylvan Pro Select 19 Restore
<blockquote data-quote="Spoondragger" data-source="post: 436609" data-attributes="member: 22022"><p>Well, fir bcx plywood and Raka epoxy are here (classy guys at Raka). Aluminum is cut and fitted. Still need to finish the front section where the bow seating will go.</p><p></p><p>Installed two bilges to replace the 750gph (???). One 850 with a float switch and a 2000. Next I'll mock up where the kicker will be mounted and start on the transom.</p></blockquote><p></p>
[QUOTE="Spoondragger, post: 436609, member: 22022"] Well, fir bcx plywood and Raka epoxy are here (classy guys at Raka). Aluminum is cut and fitted. Still need to finish the front section where the bow seating will go. Installed two bilges to replace the 750gph (???). One 850 with a float switch and a 2000. Next I'll mock up where the kicker will be mounted and start on the transom. [/QUOTE]
