Motors
1996-1998 25 hp force
<blockquote data-quote="BullfrogBowfishing" data-source="post: 342390" data-attributes="member: 13493"><p>ok so I got the motor home the recoil starter has some issues so I pulled if off when turning the engine over by hand I noticed the the flywheel was sticking or rubbing one or more of the coils on the timing plate so I popped the flywheel off coils are set to far out the is a special tool for setting the air gap. I need to get ahold of one and go from there. other than that the motor seems clean and should be decent if I can get her up and running</p></blockquote><p></p>
[QUOTE="BullfrogBowfishing, post: 342390, member: 13493"] ok so I got the motor home the recoil starter has some issues so I pulled if off when turning the engine over by hand I noticed the the flywheel was sticking or rubbing one or more of the coils on the timing plate so I popped the flywheel off coils are set to far out the is a special tool for setting the air gap. I need to get ahold of one and go from there. other than that the motor seems clean and should be decent if I can get her up and running [/QUOTE]
Motors
