Boat House
1998 18' polar Kraft mod v
<blockquote data-quote="Bearclaw" data-source="post: 432721" data-attributes="member: 22170"><p>I have a 79 polar kraft and it has aluminum over plywood in the floor came from the factory this way. It's so old the foam in it was large blocks, not the poured in kind,or that was in the front deck, I'm not sure what's under the plywood. I've recently been working on a tracker. I've taken some out,some came out easy,some spots I used a saws all with a long blade to cut thru it. It didn't seem too bad to remove</p></blockquote><p></p>
[QUOTE="Bearclaw, post: 432721, member: 22170"] I have a 79 polar kraft and it has aluminum over plywood in the floor came from the factory this way. It's so old the foam in it was large blocks, not the poured in kind,or that was in the front deck, I'm not sure what's under the plywood. I've recently been working on a tracker. I've taken some out,some came out easy,some spots I used a saws all with a long blade to cut thru it. It didn't seem too bad to remove [/QUOTE]
Boat House
