Motors
2001 25hp Johnson
<blockquote data-quote="samw" data-source="post: 323097" data-attributes="member: 12264"><p>Spent most of the day yesterday working on the motor, new fuel lines new filter and fresh gas with seafoam and stabil and she runs perfect. The water pump works fine, forward and reverse gears work smooth all in all I think it si a solid little motor. Thanks guys for all your input. Now its time to correct all of the problems the PO made on the hull. Just trying to get it where I can use it for now and modify it this winter. I've got a lot of great ideas from some of the builds I've seen here.</p></blockquote><p></p>
[QUOTE="samw, post: 323097, member: 12264"] Spent most of the day yesterday working on the motor, new fuel lines new filter and fresh gas with seafoam and stabil and she runs perfect. The water pump works fine, forward and reverse gears work smooth all in all I think it si a solid little motor. Thanks guys for all your input. Now its time to correct all of the problems the PO made on the hull. Just trying to get it where I can use it for now and modify it this winter. I've got a lot of great ideas from some of the builds I've seen here. [/QUOTE]
Motors
2001 25hp Johnson
