2004 PT175 Floor replacement alternative
<blockquote data-quote="dearl" data-source="post: 468967" data-attributes="member: 1760"><p>Properly treated exterior plywood will last a very long time. The key is to not letting it sit out in the weather and just soak up water. I rebuilt a tracker floor once but went back with.125 aluminum sheet. It really made the whole boat feel more rigid, plus I never had to worry about wet floor wood. Take care and measure carefully, if you go this route, everything will be off close to a 1/2" in height due to not having the wood thickness.</p></blockquote><p></p>
[QUOTE="dearl, post: 468967, member: 1760"] Properly treated exterior plywood will last a very long time. The key is to not letting it sit out in the weather and just soak up water. I rebuilt a tracker floor once but went back with.125 aluminum sheet. It really made the whole boat feel more rigid, plus I never had to worry about wet floor wood. Take care and measure carefully, if you go this route, everything will be off close to a 1/2" in height due to not having the wood thickness. [/QUOTE]
