Motors
20hp 4stroke suzuki
<blockquote data-quote="scoobeb" data-source="post: 338449" data-attributes="member: 6843"><p>Forgot to mention,this motor is so easy to do maintenance on also.Very simple to do to the water pump impeller,pull the plugs,change the oil and filter,change the lower unit oil.Save yourself a ton of money and just do it yourself if you decide to buy this motor after i put stats up and you like what you see.Plus you can use what oils you want,i only use full synthetic oils in the engine and lower unit after say the 20hr oil change,that is plenty of time for the motor to break in.I use royal purple marine oil for the engine and for the lower unit.</p></blockquote><p></p>
[QUOTE="scoobeb, post: 338449, member: 6843"] Forgot to mention,this motor is so easy to do maintenance on also.Very simple to do to the water pump impeller,pull the plugs,change the oil and filter,change the lower unit oil.Save yourself a ton of money and just do it yourself if you decide to buy this motor after i put stats up and you like what you see.Plus you can use what oils you want,i only use full synthetic oils in the engine and lower unit after say the 20hr oil change,that is plenty of time for the motor to break in.I use royal purple marine oil for the engine and for the lower unit. [/QUOTE]
Motors
20hp 4stroke suzuki
