Boat House
3m 5200 how to use?
<blockquote data-quote="DaleH" data-source="post: 372499" data-attributes="member: 15636"><p>Never use any SS in direct contact w/ aluminum; you will get galvanic corrosion due to dissimilar metals. One can simply insulate the SS from the aluminum by putting nylon washers under the heads or nuts if the fastener, or heatshrink over the bolt body, or by applying a special grease like Tef-Gel.</p><p></p><p>This effect of galvanic corrosion is greatly increased on boats used in brackish or salt waters.</p></blockquote><p></p>
[QUOTE="DaleH, post: 372499, member: 15636"] Never use any SS in direct contact w/ aluminum; you will get galvanic corrosion due to dissimilar metals. One can simply insulate the SS from the aluminum by putting nylon washers under the heads or nuts if the fastener, or heatshrink over the bolt body, or by applying a special grease like Tef-Gel. This effect of galvanic corrosion is greatly increased on boats used in brackish or salt waters. [/QUOTE]
Boat House
3m 5200 how to use?
