Motors
4 HP Mercury and Jon boat
<blockquote data-quote="Sinkingfast" data-source="post: 410254" data-attributes="member: 15306"><p>Make a mark on the prop that won't get washed off straight across from the cotter pin loop. Use the motor until you feel that slip. Then check the mark on the prop. If it has moved in relation to the cotter pin loop it is a spun prop. </p><p></p><p>My 15hp kinda does that as I go over varying water temps. I live on a river with varying water temps and the prop does bite differently causing what seems like surging. I notice it more on my merc 4.5,1979 on my 1232jon.</p></blockquote><p></p>
[QUOTE="Sinkingfast, post: 410254, member: 15306"] Make a mark on the prop that won't get washed off straight across from the cotter pin loop. Use the motor until you feel that slip. Then check the mark on the prop. If it has moved in relation to the cotter pin loop it is a spun prop. My 15hp kinda does that as I go over varying water temps. I live on a river with varying water temps and the prop does bite differently causing what seems like surging. I notice it more on my merc 4.5,1979 on my 1232jon. [/QUOTE]
Motors
