Motors
40 hp Mariner
<blockquote data-quote="trophyhunter" data-source="post: 209073" data-attributes="member: 6270"><p>Well obviously it's sending a signal to the ignition ready / oil-overhead chime. Do you have a point and shoot thermometer to get some temp readings and see if it's getting to hot? That motor has an overheat sensor and a low oil level sensor in the tank as mentioned, first thing would be to see which wire is sending the signal to the alarm and isolate it from there.</p></blockquote><p></p>
[QUOTE="trophyhunter, post: 209073, member: 6270"] Well obviously it's sending a signal to the ignition ready / oil-overhead chime. Do you have a point and shoot thermometer to get some temp readings and see if it's getting to hot? That motor has an overheat sensor and a low oil level sensor in the tank as mentioned, first thing would be to see which wire is sending the signal to the alarm and isolate it from there. [/QUOTE]
Motors
40 hp Mariner
