Motors
40 hp Yamaha cuts out at high rpm
<blockquote data-quote="huntinfool" data-source="post: 211829" data-attributes="member: 1931"><p>I clean carbs all the time. I personally have cleaned carbs, ran a motor and they acted like I had not cleaned them. Took them back off and they had picked up some trash somewhere and needed to be cleaned again. Also, you never know when one piece of trash gets sucked up into the jet and that is the only problem. That motor should be fairly easy to pull the carb. At lease if you did pull it you could eliminate that as the problem.</p></blockquote><p></p>
[QUOTE="huntinfool, post: 211829, member: 1931"] I clean carbs all the time. I personally have cleaned carbs, ran a motor and they acted like I had not cleaned them. Took them back off and they had picked up some trash somewhere and needed to be cleaned again. Also, you never know when one piece of trash gets sucked up into the jet and that is the only problem. That motor should be fairly easy to pull the carb. At lease if you did pull it you could eliminate that as the problem. [/QUOTE]
Motors
