Off The Water
Watering Hole
$5 A-RIGS!!!!!!!!!! i found them!!!!!!!
<blockquote data-quote="LonLB" data-source="post: 239823" data-attributes="member: 4391"><p>Honestly, I think the snap swivel for each bait is a mistake. Most of those baits are keel waited enough that they won't twist your line. Even without swim baits, and using grubs (which I plan to do)</p><p>Plus doing away with the snap/swivel would make it at least a little more stealthy.</p><p></p><p>However, the biggest line twist issue with this setup would be the entire thing spinning when being cast out. Personally I'm going to use one with split rings holding the baits, and a swivel with split ring attached to the rig itself.</p></blockquote><p></p>
[QUOTE="LonLB, post: 239823, member: 4391"] Honestly, I think the snap swivel for each bait is a mistake. Most of those baits are keel waited enough that they won't twist your line. Even without swim baits, and using grubs (which I plan to do) Plus doing away with the snap/swivel would make it at least a little more stealthy. However, the biggest line twist issue with this setup would be the entire thing spinning when being cast out. Personally I'm going to use one with split rings holding the baits, and a swivel with split ring attached to the rig itself. [/QUOTE]
Off The Water
Watering Hole
