Motors
'88 30hp Evinrude Woes
<blockquote data-quote="Ictalurus" data-source="post: 206730" data-attributes="member: 2983"><p>Can't help on the running issue, but I may have some info on the starting problem. I had to replace my pin and plastic piece that catches the gears when I try to start the motor (8 HP Evinrude). The little plastic piece had worn down and my motor had the same symptoms as you described, wouldn't recoil and seemed like it wouldn't catch when I tried to pull the rope. Was a $10.00 fix and hasn't caused any problems since.</p></blockquote><p></p>
[QUOTE="Ictalurus, post: 206730, member: 2983"] Can't help on the running issue, but I may have some info on the starting problem. I had to replace my pin and plastic piece that catches the gears when I try to start the motor (8 HP Evinrude). The little plastic piece had worn down and my motor had the same symptoms as you described, wouldn't recoil and seemed like it wouldn't catch when I tried to pull the rope. Was a $10.00 fix and hasn't caused any problems since. [/QUOTE]
Motors
