Motors
9.5 johnson problems
<blockquote data-quote="Johny25" data-source="post: 253874" data-attributes="member: 7791"><p>Did you try pumping the priming ball between the fuel tank and engine while it is running? If you pump the ball and the engine runs better then it is the fuel pump. </p><p></p><p> It surely sounds like a fuel delivery problem so if it is not the pump and you already replaced the fuel lines then I would be thinking carburetor next. Maybe a plugged high speed jet or something?</p></blockquote><p></p>
[QUOTE="Johny25, post: 253874, member: 7791"] Did you try pumping the priming ball between the fuel tank and engine while it is running? If you pump the ball and the engine runs better then it is the fuel pump. It surely sounds like a fuel delivery problem so if it is not the pump and you already replaced the fuel lines then I would be thinking carburetor next. Maybe a plugged high speed jet or something? [/QUOTE]
Motors
