Motors
9.9 johnson will not even 'pop'
<blockquote data-quote="JMichael" data-source="post: 323201" data-attributes="member: 7544"><p>Just because a coil generates enough spark to give you a good jolt, that doesn't mean the ign system is working well enough to make the motor run. The spark needs to be a heavy blue arch that will jump across a ¼" or so gap. Are the plugs getting wet with gas when you try to start it or are they always dry. If they're dry, the fuel is not getting to the cylinders regardless of how well the fuel pump or anything else is working in the fuel system.</p></blockquote><p></p>
[QUOTE="JMichael, post: 323201, member: 7544"] Just because a coil generates enough spark to give you a good jolt, that doesn't mean the ign system is working well enough to make the motor run. The spark needs to be a heavy blue arch that will jump across a ¼" or so gap. Are the plugs getting wet with gas when you try to start it or are they always dry. If they're dry, the fuel is not getting to the cylinders regardless of how well the fuel pump or anything else is working in the fuel system. [/QUOTE]
Motors
