Motors
9.9hp Evinrude Lower Unit Removal
<blockquote data-quote="perchjerker" data-source="post: 415843" data-attributes="member: 20605"><p>I dont know if I would be running anything through it, it might cause more harm than good</p><p></p><p>does it have a thermostat housing or other opening to the cooling system that you could look in to inspect for corrosion?</p><p></p><p>I know some motors you can take the exhaust cover off the side of the motor and it would expose the cooling passages, might be worth doing</p><p></p><p>if it were my motor I would probably just run it and monitor it carefully for a while until you have confidence that its ok</p></blockquote><p></p>
[QUOTE="perchjerker, post: 415843, member: 20605"] I dont know if I would be running anything through it, it might cause more harm than good does it have a thermostat housing or other opening to the cooling system that you could look in to inspect for corrosion? I know some motors you can take the exhaust cover off the side of the motor and it would expose the cooling passages, might be worth doing if it were my motor I would probably just run it and monitor it carefully for a while until you have confidence that its ok [/QUOTE]
Motors
