Off The Water
Watering Hole
A morality question
<blockquote data-quote="bAcKpAiN" data-source="post: 25869" data-attributes="member: 169"><p>I wouldn't take it. Here is the main reason I say that, sure ou may know "the spots" if you do take it, but at what cost? Not only that but knowing "spots" is only a small part of the equation. What I would do is take the opportunity while fishing to pick the guides brain on why each spot you may end up at is attractive. What to look for when fishing that particular river at different times of the year. That way in the future you can find multiple places to try on your own instead of looking at a gps graph. You will also get a TON more information that way by giving him an opportunity to impart his knowledge and experience.</p></blockquote><p></p>
[QUOTE="bAcKpAiN, post: 25869, member: 169"] I wouldn't take it. Here is the main reason I say that, sure ou may know "the spots" if you do take it, but at what cost? Not only that but knowing "spots" is only a small part of the equation. What I would do is take the opportunity while fishing to pick the guides brain on why each spot you may end up at is attractive. What to look for when fishing that particular river at different times of the year. That way in the future you can find multiple places to try on your own instead of looking at a gps graph. You will also get a TON more information that way by giving him an opportunity to impart his knowledge and experience. [/QUOTE]
Off The Water
Watering Hole
A morality question
