Boat House
ACM Panels used in Jon Boat
<blockquote data-quote="DanMarino" data-source="post: 121886" data-attributes="member: 2542"><p>I'm installing a floor and extending the front deck on my Fisher 1648 MV.</p><p></p><p>For the floor material I'm using 4 x 8 sheets of polyethylene that are clad on both sides with aluminum. The total thickness of the sheets is 1/8 inch. The stuff is easy to work with and light weight. So far it's going well. I purchased the sheets from a local sign printing supply store. The products I used are called Omega-Bond and Dibond. Got scratch and dent sheets for $20 and $35. Much cheaper than the $225 sheets of aluminum that I priced from other places. The sheets are pre-painted white on both sides and come with a plastic film that you peel off. The sheets are used to print weatherproof outdoor signs.</p></blockquote><p></p>
[QUOTE="DanMarino, post: 121886, member: 2542"] I'm installing a floor and extending the front deck on my Fisher 1648 MV. For the floor material I'm using 4 x 8 sheets of polyethylene that are clad on both sides with aluminum. The total thickness of the sheets is 1/8 inch. The stuff is easy to work with and light weight. So far it's going well. I purchased the sheets from a local sign printing supply store. The products I used are called Omega-Bond and Dibond. Got scratch and dent sheets for $20 and $35. Much cheaper than the $225 sheets of aluminum that I priced from other places. The sheets are pre-painted white on both sides and come with a plastic film that you peel off. The sheets are used to print weatherproof outdoor signs. [/QUOTE]
Boat House
