Boat House
Alum Floor Thickness
<blockquote data-quote="fender66" data-source="post: 151817" data-attributes="member: 2990"><p>I filled my floor (between the ribs) with foam that was the same height of the boat ribs, then used an .063 or 1/16th sheeting of aluminum to cover my floor. Used aluminum rivets to secure it to the ribs and it works perfectly. No sagging, and it was very light in weight which I need to watch because I'm running a jet. I could not be happier with the way the floor turned out. Now I'm working on the back deck....that will be 1/8 inch with supports close enough to prevent sagging in between. (this was all on my old tin though)</p><p></p><p>I'll try to remember to load some pics of the project later tonight maybe. If the weather holds, I'm going fishing after work though.</p></blockquote><p></p>
[QUOTE="fender66, post: 151817, member: 2990"] I filled my floor (between the ribs) with foam that was the same height of the boat ribs, then used an .063 or 1/16th sheeting of aluminum to cover my floor. Used aluminum rivets to secure it to the ribs and it works perfectly. No sagging, and it was very light in weight which I need to watch because I'm running a jet. I could not be happier with the way the floor turned out. Now I'm working on the back deck....that will be 1/8 inch with supports close enough to prevent sagging in between. (this was all on my old tin though) I'll try to remember to load some pics of the project later tonight maybe. If the weather holds, I'm going fishing after work though. [/QUOTE]
Boat House
