Boat House
Alumacraft 1648 Mod Help
<blockquote data-quote="bassboy1" data-source="post: 68531" data-attributes="member: 55"><p>Couple minor things in that drawing. First of all, if you are going to be running a tiller, you do not want to extend your deck forward, or you will be sitting on a pedestal seat, while operating a tiller. Not exactly my idea of fun. You are also likely going to want a pedestal base offset on the right, so you can reach the tiller without twisting your arm around you. </p><p></p><p>Second thing. The problem with putting a battery in those boxes is that they taper in at the bottom (hull does). While the top would fit a battery, you couldn't put it all the way in, as it tapers to nothing.</p></blockquote><p></p>
[QUOTE="bassboy1, post: 68531, member: 55"] Couple minor things in that drawing. First of all, if you are going to be running a tiller, you do not want to extend your deck forward, or you will be sitting on a pedestal seat, while operating a tiller. Not exactly my idea of fun. You are also likely going to want a pedestal base offset on the right, so you can reach the tiller without twisting your arm around you. Second thing. The problem with putting a battery in those boxes is that they taper in at the bottom (hull does). While the top would fit a battery, you couldn't put it all the way in, as it tapers to nothing. [/QUOTE]
Boat House
