Boat House
Aluminum Floor Thickness Issues
<blockquote data-quote="Shoedawg" data-source="post: 406093" data-attributes="member: 13490"><p>Thanks for the reply Dale and adding up the weights. I didn't think .090 would be a common mil size and cheaper (potentially). Most of the Tinners on here use various sized thicknesses from .090 to .125, I just think .125 would be over kill for the set-up I have. The going thickness seems to be about .090. I assume there is little flex to .090 and should be more than enough support for my floor.</p><p></p><p>I have seen others that have recommended .125 for front casting decks. Do you think .090 will be enough (with proper structural support/design) to support one?</p></blockquote><p></p>
[QUOTE="Shoedawg, post: 406093, member: 13490"] Thanks for the reply Dale and adding up the weights. I didn't think .090 would be a common mil size and cheaper (potentially). Most of the Tinners on here use various sized thicknesses from .090 to .125, I just think .125 would be over kill for the set-up I have. The going thickness seems to be about .090. I assume there is little flex to .090 and should be more than enough support for my floor. I have seen others that have recommended .125 for front casting decks. Do you think .090 will be enough (with proper structural support/design) to support one? [/QUOTE]
Boat House
