Motors
Another lark paint ?
<blockquote data-quote="putback" data-source="post: 431964" data-attributes="member: 15012"><p>Prep near done, about ready for primer. That means a decision. Which primer, read your primer article on site. Better to ask in this case. The panels have good sound paint. Clean and finish sanded to 320 grit. Some bare aluminum exposed where they were scratched or chiped. Those spots were feathered out, largest one being dime size. After I finish priming and smoothing I need to scrape of the letter tops, then top coat and rescrape. So, I'm priming existing paint, minute spots of bare aluminum, And the letters need to be scraped. Will be top coating these panels and entire motor with urethane based. Which primer would you use.</p></blockquote><p></p>
[QUOTE="putback, post: 431964, member: 15012"] Prep near done, about ready for primer. That means a decision. Which primer, read your primer article on site. Better to ask in this case. The panels have good sound paint. Clean and finish sanded to 320 grit. Some bare aluminum exposed where they were scratched or chiped. Those spots were feathered out, largest one being dime size. After I finish priming and smoothing I need to scrape of the letter tops, then top coat and rescrape. So, I'm priming existing paint, minute spots of bare aluminum, And the letters need to be scraped. Will be top coating these panels and entire motor with urethane based. Which primer would you use. [/QUOTE]
Motors
