Motors
Another outboard running issue
<blockquote data-quote="kofkorn" data-source="post: 359708" data-attributes="member: 7076"><p>Just want to make sure that you are turning the manual primer off after it runs for about 15 sec. The little lever needs to be in-line with the fuel path to make sure it is off. If you aren't turning off the primer, you may be flooding the engine. That may explain why it runs well for about a minute before it stalls on you. </p><p></p><p>If not, maybe someone else can chime in...</p><p></p><p>Good luck!</p></blockquote><p></p>
[QUOTE="kofkorn, post: 359708, member: 7076"] Just want to make sure that you are turning the manual primer off after it runs for about 15 sec. The little lever needs to be in-line with the fuel path to make sure it is off. If you aren't turning off the primer, you may be flooding the engine. That may explain why it runs well for about a minute before it stalls on you. If not, maybe someone else can chime in... Good luck! [/QUOTE]
Motors
