Boat House
Any experience with a tunnel hull and prop motor
<blockquote data-quote="Zum" data-source="post: 203783" data-attributes="member: 349"><p>I'd try the boat out before adding any foils.</p><p>It might be perfect as is...if you add the jack plate after,thats going to make some changes as well,might help if needed.</p><p>The little I know about props the 4 blade 1 will give you a better holeshot,maybe alittle less topend.</p><p>If you normally run a 14 pitch,3 blade prop,you normally drop a pitch when going to a 4 blade.</p><p>I own a 1652 jet tunnel but run a prop.I can't complain,it raises the outboard so I can get into alittle skinner water.Your going to loose alittle top end with the tunnel hull..3-5mph.</p><p>Welcome to the site.</p></blockquote><p></p>
[QUOTE="Zum, post: 203783, member: 349"] I'd try the boat out before adding any foils. It might be perfect as is...if you add the jack plate after,thats going to make some changes as well,might help if needed. The little I know about props the 4 blade 1 will give you a better holeshot,maybe alittle less topend. If you normally run a 14 pitch,3 blade prop,you normally drop a pitch when going to a 4 blade. I own a 1652 jet tunnel but run a prop.I can't complain,it raises the outboard so I can get into alittle skinner water.Your going to loose alittle top end with the tunnel hull..3-5mph. Welcome to the site. [/QUOTE]
Boat House
