Off The Water
Watering Hole
Any walleye hunters here?
<blockquote data-quote="Wallijig" data-source="post: 245229" data-attributes="member: 6398"><p>I live for big eye fishing. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite8" alt=":D" title="Big grin :D" loading="lazy" data-shortname=":D" /> </p><p> Males should be setting up for prespawn and be somewhat aggressive. At this time or yr in open water, I would vertically jig with lead head and minnow. I would use light as lead head as could get away with, depending on current and depth. I would look for sandy points with deeper water close by. During day work deep side, Close to sunset work shallower. Also could cast shallows around sunset and retrieve very slow popping it off bottom every little bit. Could also try lindy rig with minnow in deep trolling very slow. If they are not hitting hard & feel some taps, give them line for few seconds let them inhale it, then set hook. If you have little current it is a plus.</p></blockquote><p></p>
[QUOTE="Wallijig, post: 245229, member: 6398"] I live for big eye fishing. :D Males should be setting up for prespawn and be somewhat aggressive. At this time or yr in open water, I would vertically jig with lead head and minnow. I would use light as lead head as could get away with, depending on current and depth. I would look for sandy points with deeper water close by. During day work deep side, Close to sunset work shallower. Also could cast shallows around sunset and retrieve very slow popping it off bottom every little bit. Could also try lindy rig with minnow in deep trolling very slow. If they are not hitting hard & feel some taps, give them line for few seconds let them inhale it, then set hook. If you have little current it is a plus. [/QUOTE]
Off The Water
Watering Hole
