Electrical
Auto Bilge stopped working
<blockquote data-quote="JL8Jeff" data-source="post: 455895" data-attributes="member: 12995"><p>We had the pressure switch go bad in our basin pump in the house a couple of months ago. So they aren't really much better than a normal float switch. I've had a float switch where the metal ball inside got stuck and it didn't pump out the boat. I've also had stuff block the float switch from lifting up but that was my fault for not keeping it clear around the switch. I've also had a pump get an air bubble in the line and not be able to pump out the water. So just keep an eye out on things like the float switch, pump and lines.</p></blockquote><p></p>
[QUOTE="JL8Jeff, post: 455895, member: 12995"] We had the pressure switch go bad in our basin pump in the house a couple of months ago. So they aren't really much better than a normal float switch. I've had a float switch where the metal ball inside got stuck and it didn't pump out the boat. I've also had stuff block the float switch from lifting up but that was my fault for not keeping it clear around the switch. I've also had a pump get an air bubble in the line and not be able to pump out the water. So just keep an eye out on things like the float switch, pump and lines. [/QUOTE]
Electrical
