Electrical
Battery Size
<blockquote data-quote="onthewater102" data-source="post: 442995" data-attributes="member: 13702"><p>Should be 13v or so after coming off the charger - if you let it sit for a while it should fall back to 12.6 or 12.7 and hold there.</p><p></p><p>I've got walmart's 29DC batteries in my boats, but one is getting on 9yrs old while the other is close to 7 so I'm anticipating they're not going to be with me too much longer. They hold a charge fine but they just don't have the capacity they once did. I'm going to try knocking them around and seeing if that will help clean up the plates, as I've had good luck with that in the past.</p></blockquote><p></p>
[QUOTE="onthewater102, post: 442995, member: 13702"] Should be 13v or so after coming off the charger - if you let it sit for a while it should fall back to 12.6 or 12.7 and hold there. I've got walmart's 29DC batteries in my boats, but one is getting on 9yrs old while the other is close to 7 so I'm anticipating they're not going to be with me too much longer. They hold a charge fine but they just don't have the capacity they once did. I'm going to try knocking them around and seeing if that will help clean up the plates, as I've had good luck with that in the past. [/QUOTE]
Electrical
Battery Size
