Boat House
Bilge Pump Question
<blockquote data-quote="user 10949" data-source="post: 320864" data-attributes="member: 10949"><p>The highest flow rate that fits your budget would be the best choice. A bilge being a safety device will only protect you up to just below it's "actual flowrate" of incoming water. i say "actual flowrate" because I've never seen a bilge run anywhere near it's claimed rate of flow.</p><p></p><p>worst case scenario would be like a completely failed bulkhead or tear in the hull.</p><p></p><p>if my math is correct a 3/4" hole , 2ft underwater, would take on 20 +- gpm</p><p></p><p>an empty 1448 with 24" side walls holds 830 +- gallons. it's full to the rim in 35 +- minutes with no bilge pump.</p></blockquote><p></p>
[QUOTE="user 10949, post: 320864, member: 10949"] The highest flow rate that fits your budget would be the best choice. A bilge being a safety device will only protect you up to just below it's "actual flowrate" of incoming water. i say "actual flowrate" because I've never seen a bilge run anywhere near it's claimed rate of flow. worst case scenario would be like a completely failed bulkhead or tear in the hull. if my math is correct a 3/4" hole , 2ft underwater, would take on 20 +- gpm an empty 1448 with 24" side walls holds 830 +- gallons. it's full to the rim in 35 +- minutes with no bilge pump. [/QUOTE]
Boat House
Bilge Pump Question
