Boat House
Bilge Pumps
<blockquote data-quote="Pruitt1222" data-source="post: 154634" data-attributes="member: 2683"><p>Mine is mounted to a rib with two ss screws, It has a auto float switch wired to it. It also is hard wired to a switch on my panel just in case. It is hosed out the side like on a bigger boat. My pump is a attwood 500gph, It will almost keep up with a missing plug when the boat is empty. Just make sure you can reach it, mine tends to suck leaves around it clog it up from time to time.</p></blockquote><p></p>
[QUOTE="Pruitt1222, post: 154634, member: 2683"] Mine is mounted to a rib with two ss screws, It has a auto float switch wired to it. It also is hard wired to a switch on my panel just in case. It is hosed out the side like on a bigger boat. My pump is a attwood 500gph, It will almost keep up with a missing plug when the boat is empty. Just make sure you can reach it, mine tends to suck leaves around it clog it up from time to time. [/QUOTE]
Boat House
Bilge Pumps
