Off The Water
Watering Hole
Boat carpet?
<blockquote data-quote="ericman" data-source="post: 377572" data-attributes="member: 11909"><p>If you use Menards Status brand or the similar stuff from Fleet Farm, or if you use marine grade carpet, you do not need to pre-cut a hole or melt a hole for the screw, simply pre-drill through the carpet, plywood and aluminum framing and run your screw, the carpet in those pictures is more of a woven carpet, but with the stuff I mentioned above, it's made differently and has NEVER un-raveled for me and I've screwed in thousands and thousands of screws through the stuff.</p></blockquote><p></p>
[QUOTE="ericman, post: 377572, member: 11909"] If you use Menards Status brand or the similar stuff from Fleet Farm, or if you use marine grade carpet, you do not need to pre-cut a hole or melt a hole for the screw, simply pre-drill through the carpet, plywood and aluminum framing and run your screw, the carpet in those pictures is more of a woven carpet, but with the stuff I mentioned above, it's made differently and has NEVER un-raveled for me and I've screwed in thousands and thousands of screws through the stuff. [/QUOTE]
Off The Water
Watering Hole
Boat carpet?
