Boat House
Boat crank winch ?
<blockquote data-quote="richg99" data-source="post: 415025" data-attributes="member: 4376"><p>All good advice above. </p><p></p><p>You might also consider adding 3x4 plastic guttering to the top of your bunks. Sliding the boat up and off is then MUCH easier than doing it off of carpet. Here is a LINK. </p><p></p><p>Cost should be around $15.00 . Don't release your straps until the hull is over the water....pretty slick stuff. richg99</p><p></p><p>https://forum.tinboats.net/viewtopic.php?f=3&t=40137</p></blockquote><p></p>
[QUOTE="richg99, post: 415025, member: 4376"] All good advice above. You might also consider adding 3x4 plastic guttering to the top of your bunks. Sliding the boat up and off is then MUCH easier than doing it off of carpet. Here is a LINK. Cost should be around $15.00 . Don't release your straps until the hull is over the water....pretty slick stuff. richg99 https://forum.tinboats.net/viewtopic.php?f=3&t=40137 [/QUOTE]
Boat House
Boat crank winch ?
