Electrical
Can I mount transducer on my front trolling motor somehow?
<blockquote data-quote="FerrisBueller" data-source="post: 323696" data-attributes="member: 11145"><p>Anyone that mounts a transducer onto a Powerdrive has done the same thing essentially where you zip tie it at the very bottom and then the wire runs freely up the shaft and is fastened in some fashion above the depth collar. It seems scary at first but many people do it this way and if you be careful you shouldn't have any issues. </p><p></p><p>You really just need to weigh your options and how much thinking you want to put into it. You can mount it to a separate pole and deploy that on its own as well as marshman was suggesting, in the end its how you want it to be done. </p><p></p><p>And it's definitely worth having the transducer right up front for accurate measurements.</p></blockquote><p></p>
[QUOTE="FerrisBueller, post: 323696, member: 11145"] Anyone that mounts a transducer onto a Powerdrive has done the same thing essentially where you zip tie it at the very bottom and then the wire runs freely up the shaft and is fastened in some fashion above the depth collar. It seems scary at first but many people do it this way and if you be careful you shouldn't have any issues. You really just need to weigh your options and how much thinking you want to put into it. You can mount it to a separate pole and deploy that on its own as well as marshman was suggesting, in the end its how you want it to be done. And it's definitely worth having the transducer right up front for accurate measurements. [/QUOTE]
Electrical
