Motors
Cant get this to start, 1971 Evinrude 25hp
<blockquote data-quote="crazymanme2" data-source="post: 148487" data-attributes="member: 1634"><p>You should pull the carb off,it is probably gumed up.It will need a new water pump impeller also.Wouldn't hurt to put a little oil down the cylinders.Try a little gas ,oil mix in the carb.No starting fluid.That motor has points,but if you have good spark that may be ok just maybe check down the road.</p><p> Those are good motors.I have a 1976.</p></blockquote><p></p>
[QUOTE="crazymanme2, post: 148487, member: 1634"] You should pull the carb off,it is probably gumed up.It will need a new water pump impeller also.Wouldn't hurt to put a little oil down the cylinders.Try a little gas ,oil mix in the carb.No starting fluid.That motor has points,but if you have good spark that may be ok just maybe check down the road. Those are good motors.I have a 1976. [/QUOTE]
Motors
