Boat House
Circular saw blade
<blockquote data-quote="eshaw" data-source="post: 460665" data-attributes="member: 22134"><p>If you want something that will last you I'd bite the bullet and have one made with carbide teeth. As long as you're not using excessive feed rates it can even cut through an occasional nail. Also, if you damaged a tooth it can be welded and finished back to original and a new carbide tip silver soldered on and ground to the matching profile.</p></blockquote><p></p>
[QUOTE="eshaw, post: 460665, member: 22134"] If you want something that will last you I'd bite the bullet and have one made with carbide teeth. As long as you're not using excessive feed rates it can even cut through an occasional nail. Also, if you damaged a tooth it can be welded and finished back to original and a new carbide tip silver soldered on and ground to the matching profile. [/QUOTE]
Boat House
Circular saw blade
