Motors
classic 50 hp 1989
<blockquote data-quote="clarego" data-source="post: 274582" data-attributes="member: 5137"><p>there's damage to the prop it needs changed it is bent (been needing change) just havent got around to doing it its not that bad of shape but enough i think it may cause problems . i got line in it this weekend and hope there is no signs of water getting in i just had the whole impeller and seals change. i just want to check it and learn how to take one off </p><p></p><p>how do you check for signs of water through the vent plug or through the fill tag again everything was changed and if the line caused damage to the seal s will i see it</p></blockquote><p></p>
[QUOTE="clarego, post: 274582, member: 5137"] there's damage to the prop it needs changed it is bent (been needing change) just havent got around to doing it its not that bad of shape but enough i think it may cause problems . i got line in it this weekend and hope there is no signs of water getting in i just had the whole impeller and seals change. i just want to check it and learn how to take one off how do you check for signs of water through the vent plug or through the fill tag again everything was changed and if the line caused damage to the seal s will i see it [/QUOTE]
Motors
classic 50 hp 1989
