Motors
Cleaning In-Tank Filter
<blockquote data-quote="turbotodd" data-source="post: 470409" data-attributes="member: 7376"><p>I have not seen an in-tank "filter". I have seen some that had a screen on the bottom of the pickup tube but it's not necessarily a filter, per say. A spin on filter/separator specifically designed for boating would be fine--actually recommended by most boat and motor manufacturers. On EFI motors the fuel pump sits down in a little tank and similar to a car, the pump module usually has a filter on it; many call it a "sock"--and they will sometimes plug. Unfortunately many of them are not available separate from the pump assembly.</p></blockquote><p></p>
[QUOTE="turbotodd, post: 470409, member: 7376"] I have not seen an in-tank "filter". I have seen some that had a screen on the bottom of the pickup tube but it's not necessarily a filter, per say. A spin on filter/separator specifically designed for boating would be fine--actually recommended by most boat and motor manufacturers. On EFI motors the fuel pump sits down in a little tank and similar to a car, the pump module usually has a filter on it; many call it a "sock"--and they will sometimes plug. Unfortunately many of them are not available separate from the pump assembly. [/QUOTE]
Motors
