Off The Water
Watering Hole
Computer screen question
<blockquote data-quote="wasilvers" data-source="post: 115933" data-attributes="member: 1776"><p>To make them round again (assuming you are using windows XP - </p><p>Go to the desktop, right click and choose properties - this brings up display properties, click the 'settings' tab and adjust the screen resolution to the 'more' side, experiment a bit till you get one that looks right. It gives you 15 seconds to revert back to the old one without you even touching it. Your monitor has a preferred resolution (probably on the box), if you choose this and the print is too hard to read, just find one of the screen resolutions that maintain the same ratio as the preferred method. I usually do the preferred method and adjust other things, but those other things can affect other programs... so I'll not metion them here :wink:</p></blockquote><p></p>
[QUOTE="wasilvers, post: 115933, member: 1776"] To make them round again (assuming you are using windows XP - Go to the desktop, right click and choose properties - this brings up display properties, click the 'settings' tab and adjust the screen resolution to the 'more' side, experiment a bit till you get one that looks right. It gives you 15 seconds to revert back to the old one without you even touching it. Your monitor has a preferred resolution (probably on the box), if you choose this and the print is too hard to read, just find one of the screen resolutions that maintain the same ratio as the preferred method. I usually do the preferred method and adjust other things, but those other things can affect other programs... so I'll not metion them here :wink: [/QUOTE]
Off The Water
Watering Hole
