Boat House
Corrosion Issue
<blockquote data-quote="spotco2" data-source="post: 284639" data-attributes="member: 6117"><p>Change the bunk boards to untreated wood coated with 3 or 4 coats of Spar and apply new carpet.</p><p></p><p>Use a flap disk or cupped wire brush on an angle grinder to remove the contaminants from the bottom of the boat.</p><p></p><p>Coat the bottom of the boat with something like Steel Flex, Gluvit ot Coat It.</p><p></p><p>Problem solved.</p><p></p><p>Cost should be under $200 and can be done in a weekend.</p></blockquote><p></p>
[QUOTE="spotco2, post: 284639, member: 6117"] Change the bunk boards to untreated wood coated with 3 or 4 coats of Spar and apply new carpet. Use a flap disk or cupped wire brush on an angle grinder to remove the contaminants from the bottom of the boat. Coat the bottom of the boat with something like Steel Flex, Gluvit ot Coat It. Problem solved. Cost should be under $200 and can be done in a weekend. [/QUOTE]
Boat House
Corrosion Issue
